1 - 8 of 8 Posts
I was just wondering if it is relatively easy to change the oxygen sensors myself, and what tools i would need to do the job correctly. my check engine light has been coming periodically for some time now, and it is getting annoying. thanks for the help.
91coupeLS
Its not too difficult. Its similar to changing a spark plug. You need an oxygen sensor socket to get it out. You can get them at most autoparts stores. The trick is getting the old one out. When I changed mine they were really stuck. Use liquid wrench or something. Be patient, it may require a significant amount of torque to bust it loose.
$235 CDN for 1 and you need a Left side and Right side!! (ie 2)
The engine light will stay on and upon "jumping" the service connector, it will flash a # of times indicating that that part is failing.
I had to replace mine after my head gasket job. The dealer was going to give them to me for $190 (reg~$235 each) but my mechanic found some bosch universal ones for $150 each. The labour was about 1.5 hours. It is a tight squeeze to get out the o2 sensors and because I went with universal sensors you have to cut the factory harness and rewire the 4 wire sensor. It is imperative that you know which wires are which (hint.... owners manual electrical diagram).
The reason these sensors are so expensive is because they are heated 4 wire sensors. G1 legend have normal 2 wire sensors. They were a very hard to find tem in Canada. 1 sensor came from Toronto and 1 sensor came from Vancouver. These were the only ones I could find in Canada!!! Out of all the major parts suppliers (Auto Value Parts, NAPA, Part Source, etc) no one could had them or wanted to get them. I guess they are a rare failure on these cars and that is why they are so expensive and hard to find.
NGK, those guys who make spark plugs also have an of-shoot company, NTK.
NTK makes for our cars, but I too could not find anyone who could supply them.
Had to go with OEM. A friend who works @ Acura in parts, gave me them for around $170 each.
Like the saying goes "...it's who you know" ;)
1 - 8 of 8 Posts
