ntujyug said:
Is it just me or you all find the radiator hose clamps to be a Pain-In-The-As?
Went out and spend $3.00 clamps at AutoZone and replaced them. It is rediculous that these clamps required a special tool.
No. A spec tool is not needed. I used always a adjustable joint pliers to take off those clamps. But you're right, because it's sometimes really a PITA.
The radiator hose is held on by a standard hose clamp which can be loosened using a plier. Take a plier, press both ends of the clamp together and slide tha clamp back down. Once the clamp is loose you should be able to encourage the hose off with gentle persistance and harsh language
. It works always
Here are the steps...
1. Loosen the clamp securing the hose to the radiator, for example. Screw clamps must be loosened with a simple screwdriver. Spring clamps (like ours) are squeezed with hose clamps pliers.
2. Slide the clamp back along the hose, so that is out of way.
3. Mark the hose for identification when reassembling.
4. Twist the hose loose from its fitting.
5. If the hose can't be removed in this manner, cut a slit several inches long in it - beginning at the end. Then use a screwdriver to pry off the hose. Don't forget : The hose will have to be replaced
This should work for you. I hope it
-Mike
