Right here
As for the paint, you can simply use some high temp paint. Much much less expensive than caliper paint.
that is what i thought i left some paint on the rotors and ever sense i have developed a high speed shimmy ... i took the pads off and there is paint residue on them ..they paint can withstand temps upwards of 500 deg so it kinda get baked on the padsjcbmrtn said:It sounds bad, but I didn't worry about masking everything off. I had paint all over my rotors, because I wanted to paint the hub black as well. When I got done I just drove around a couple miles, using my brakes and viola, no more paint on the rotors. The paint doesn't stand a chance on the rotor suface.
I think it looks realy good, only thing is I painted the back of the pads as well, but I'll be replacing those soon anyway...
honestly after you finsish painting wait like 30 min and you'll be fine to drive. I personally waited like 10 min cause i had to go somewhere and they turned out perfectly fineTHE LIFE said:I WANNA DO THE SAME BUT I DON'T HAVE A GARAGE TO DO THIS IN I WILL HAVE TO DO THIS OUTSIDE BUT MY QUESTION IS IF I START EARLY IN THE MORNING LIKE 5:30 HOW LONG WILL THE PAINT DRY BEFORE I COULD THROW MY RIM BACK AND PARK IT SO I COULD LET IT DRY?????
Most of the paints at the autopart store said 3-5 hours and the paint will be dry to the touch. Even then you have to be careful because the paint can still come off pretty easily. I made the mistake of trying to put my wheel back on too soon and the tire brushed the caliper and took some of the paint off. I had to put on another few coats because of that, and that was after I had let the paint dry for a few hours.Roger said:
the only way you can hit the caliper with your rim is if your not careful its really easy to put your rim on without hitting the caliper, and if your paint is still tacky after 30 min then you probably dident wait to long between coats.infinite said:
After 10 minutes the paint will still be very wet. Even 30 minutes the paint will still be gummy and come off easily.
Wait at least 3 hours if you have to get your wheels back on.
