I have searched this forum and have found nothing close to what is happening to mine.
During idle when i gently press down my gas petal my rpms drop and it feels like its going to stall before it revs up. Also i can hear sputtering type noise. It seems as if it is comming from the left side of the engine near the firewall. Please bare with me because i dont know too much about car engines. I am mechanically inclined though. Somone told me this could be bad fuel injectors. I thought that I would ask on here before i took them out.
New Legend Member
maybe one of your sparkplug is bad or your fuel injector i use to have that problem but it was my spark plug. If u have coil pack check if it rip from the bottom rubber or if u have sparkplug wire then check that.
Ok so I ended up taking off my egr valve and low and behold the gasket on it was toally messed up. i Could see through it. So i bought a new gasket at napa and also new spark plugs changed both of them out and problem solved for now.
