I think I could be over analyzing my car but it seems after I replaced my radiator, oil and tran oil, that my steering is not as light as it used to be a lower speeds. I think I remember it being much easier at lower speeds. It has a heavy feel to it, but I am not sure if this is possible and I am not even sure if what I am feeling in the steering is abnormal. Anyone have a similar experience or is it all in my head:confused:
Might want to bleed out your power steering system. You just empty out all the fluid from the hoses and resovoir and then add the new fluid. The system needs to be bled by turning the wheel to the left and right but dont hit the stops. When you done add fluid and make sure its topped off, this could be why your getting a different feel also.
thanks for the info, I am gonna give that a try this weekend, do you happen to know how much fluid I will need to refill the system. Thanks:)
