I just installed a new high pressure hose for my power steering, but now I just realize that I can only use Honda PSF. How do I remove the generic fluid now? I don't want to break my $300+ rack & pinion just because of a $1.25 bottle of PSF.
According to the Acura manuel the upper hose on the reservor needs to be removed and a jar or tube that you can run the fluid into.
Start the car and turn the wheel from side to side.
as the reservor gets low keep adding fluid you should see a change in the fluid color when this happens your done.. Good luck!
