Recently (about 2 months ago) I replaced my driver side power window motor. The motor seemed to work fine until a couple days ago i had the window down and some how it automatically started to roll itself back up..i pushed the switch to roll it down but soon as i released it went back up. After it got back up i simply rolled it back down again. Now, it basically opens when it wants too, and even then sometimes tries to roll itself back up(this IF it will even roll down). Am i having signs of the master switch going bad or some other issue? Every other window works as it should.
[Edit]
ok...so, i'm going to try this one more time. Instead of creating a new thread i thought i'd bring this one back. I've been looking around for quite some time for a switch and have yet to find one. I'm also still very confused, and concerned as to whether or not the master window switch is what i really need to fix my problem. I can roll down all of my windows with no problem, but the drivers side only works once in a while.(hardly ever). When it does work, it comes down then shortly after rolls itself back up. I can hear A clicking noise in the door...not sure what it is. I just put in a new motor and regulator a few months ago, so those are practically brand new. Can anyone shed any light on my problem? Will replacing the master window switch most certainly fix my problem? I don't want to be running around looking for a switch when i can easily fix the problem another way.
[Edit]
