I am installing a Fosgate 600.4 to Bi Amp my MB Quart PSC 216's and a Fosgate 250.2 Bridged to run my 10" Sub.
I have a 4 ga power wire running from the battery to a distribution block in the trunk. From there, I was going to run an 8 Ga wire to each amp for power, and an 8 Ga ground wire to the frame for both amps.
My question is, is the 8 ga wire big enough for power and ground for these two amps?
-FurBall
furball - i don't know too much about those amps, but most likely they will be fine with 8 guage. i do have another suggestion tho... instead of wiring separate grounds, take and run the 8guage grounds from the amps into another distribution block, and run 4 guage from it to a grounding point in the car. in the end, it will be eiser to install because you have 1 ground connection to make and technically, you should always have your ground be the same size as your power wire. good luck,
wally
L4K3R5 F4N
As everyone said, you should be fine. I'm currently running the same power wire setup through a distribution block. It's powering a 6 channel PPI amp and an MTX monoblock at 2 ohms into 2 12" subs. I've had this setup for months without any ill effects.
