1 - 9 of 9 Posts
Legendary P*mp
hey i have a 91 legend coupe and i was wondering wat kind of prelude struts can fit my legend? do i have to do any mods? if so how hard is it? and does the rear high and low struts fit as well? please help me out. thanks in advance - jimmy
502MotorSports.com
Why are you trying to put Prelude struts on your car?
There are several applications for the LEgend....many options - http://www.shox.com is one option, http://www.NOPI.com is another.
Go for one of these -
Koni Struts/H & R Springs - 1.5" drop
" /Eibach Springs - 1.1/1.0" drop
" /Ground Control - Stock - 3.0" drop (adjustable coilovers)
Koni struts are adjustable from firm to soft.....hope this helps
Legendary P*mp
hey cody
yeah u knew wat i meant...did u put these in ur car as well? if u did, was it hard to put on? and wat brand is a good choice to put on my baby? thanks in advance - jimmy
Prelude strut bars do work in a legend with some bending. 97 prelude strut bar with the bar being bent in the middle and one of the brackets have to be bent to extend for the length of the car. From what I have read it is not too hard to do.
GOOD LUCK
Legendary P*mp
hey eye candy im new at this so please be patient with me.... i dun want to fuk up mah baby u no... so i do i go about bending the bars? and stretching the brackets? and do u no wat brand is the best? thanks and ware can i get one -jimmy
Ok
Bar = OBX 1997 Prelude Strut Bar
Brackets - On each end of the bar there is a "bracket" or clamp that must go around the 3 bolts that you can see in your engine bay that has the strut bolt in the middle. (one on each side of engine bay right above wheel) You first bolt down one side and then you are going to have to bend that bracket side enough to get the other side to go around the 3 bolts and then tighten it down.
Bar - The bar itself will now touch the top of the manifold. So before you bend the brackets you would probably be better off trying to bend the middle of the bar just a little to clear the manifold.
I believe this trend will help you out, has all the pics I think you need.
GOOD LUCK
http://secure8.vosn.net/~legend-f/vbulletin/showthread.php?s=&threadid=1921
Legendary P*mp
Discussion Starter · #8 ·
thanks eyecandy for everything
thanks again man ur info really helped me out.... i was juss wondering how much does this obx strut usually cost? thanks again man - jimmy
1 - 9 of 9 Posts
