stock auto TypeII Legend vs. a modded 94 Lude...
A Type II should definitely win, not by a big margin, but it should still take it. The lude will have the launch, but the torque and the top end of the TypeII will let you catch and pass him, hands down.
On a drag, with a good launch you will have him without a doubt. On the highway, no question... Our C32 has a wider powerband and longer legs than a peaky VTEC. Even if he has a VTEC controller and its set to kick in low(5500), he still doesnt have the RPM's to utilize the cam duration (unless its built up internally).
Remember, third gear auto is good up to around 100 mph. A good launching technique that has been pretty reliable for me is close to the brake torquing method, without revving too high.
-What i do is i have my left foot holding down the brake with my right slightly on the gas at about 700-800 rpm.
-I launch letting go of the brake while going WOT on the gas to the 5000-5500 rpm range.
-I then ease off slightly (.5 seconds) and floor it again
until the redline shift.
-This usually causes a nice chirp to second which isn't normally apparent with just wot all the way.
-Keep on it until you lead or beat him!
The regular brake torquing method doesn't work too well with the auto legend for some reason. I read about this technique from an post on the old, old UBB forum and it seems to work. You dont even need that much practice to perfect it!
Good Luck, go forth and kick some ASS!!!
