With the high cost on gas, i came too wonder... why not just fill 87?..
A Acura Legend's compression Ratio is : hmmmm... while pulling up some research for this article i just ran accross somthing.... this one site says the ratio is
"- 3,206 cc 3.2 liters 6 V front longitudinal engine with 90 mm bore, 84 mm stroke, 9.6 compression ratio,"
THIS OTHER SITE SAYS
Engine Specs:
Displacement & Type: 3,206cc, normally aspirated V6
Horsepower @ RPM: 230 hp @ 5,500 RPM
Torque @ RPM: 220 ft/lbs @ 4,500 RPM
Compression Ratio: 8.6 : 1
Redline RPM: 6,300 RPM
8.6 is quite low?.. my Vigor has a 9... ... now 9.3 is the MAX for 87 Octane... ok i will pump 91 octane if it is 9.6...
now too think of it.. i just kind of answerd my own question... but somone one want too verify what the acctual ratio is?! .. thnx!!..
Engine Specs:
