There is a fuse, but as I know it, it is shared with the seat memory. (I believe it's Fuse #15 in underdash panel).
What alarm did you get? Does it have an autostart feature?
You should be able to reset your car by disconnecting your battery without messing up anything on your alarm.
You should try resetting it. Many a time it fixes it.
After resetting, adjust the steering and seat position and set it to memory. Then test your tilt/telescoping. (Also make sure that the auto telescoping switch is set to On)
Your volume control buttons may be a different issue altogether.
