anyone know how much all of these thigns will cost at like a local body shop? like just a ballpark figure so i can get an idea plus labor. all you rockville legend owners it would be most helpful if you could chime in on this one with your experience with body shops around our area.
speed sensor replacement
fender liner replacement
tranny fluid flush
body work; 6-7 small dings, 3 paint chips
bumper realignment
brake pad replacement
oil change
any input is appreciated...thanks!
You do not need a body shop to change fluids. Seek out an independent repairer. The inner fender splash shield you can do yourself. The body refinishing is dependent upon size and location of damage, whether adjacent panels must be blended, and the repair rate for your area. There is no adjustment to be made on the Legend bumpers. They either fit or there is damage and the correct repair procedure is to put the vehicle on a frame machine, check specs, and give it a pull. You may have to replace the bumper supports. You could also have a bent bumper reinforcement. Perhaps you just have just a broken bumper slide. Can't accurately diagnose without seeing the patient.
