As I understand it, item 14 on the this AcuraOEMParts.com page
has the sole purpose of quieting down the intake at the expense of reducing laminar airflow. In the quest for getting a little more power out of my commuter car (physically or psychosomatically), I was hoping you guys had ideas on how I can remove and block off this passage. After all, I can't just yank this chamber out b/c it sits after the airbox.
Any suggestions?
I know the "proper" fix for this is to just buy a short-ram or cold air intake but a) I've already ordered a K&N panel filter (it was only $10 more than the Acura air filter) and b) I live in CA and would rather not pay real money for a CARB legal intake (if it even exists).
Concerns I can see:
a) the plug needs to be airtight since the hole is "after" the air filter
b) it can't vibrate (so getting some rubber from a rubber inner tube and use the existing hose clamp is probably not a good idea)
c) it must be secured in such a fashion that I don't have to worry about random bits flying into my throttle body.
One thought I had would be to find a 3" PVC endcap, wrap it in the rubber material, and then clamp the mess to the big intake pipe. How ghetto would that be? Should I just consider sealing the PVC endcap? Should I just say to hell with this and leave the baffle as-is?
-g
Any suggestions?
Concerns I can see:
-g
