meber
I need to have my front rotors turned real bad. I just called a shop that only works on Hondas and Acuras and I was quoted $200.00 to have the rotors turned + new pads. My question is for that much money is it worth it to get brembos and the pads that go with them? If so wqhere is the best place to get them? One more thing is changing my rotors something I can do myself or should I have a shop do it?
meber
Has anyone installed them and is it hard to do?
meber
Someone out there has to know. Please shre with me.
Thanks in advance
GS Hog
No, it isn't hard to do; especially if you are comfortable with DIY.
You will need one special tool and that is an impact screwdriver to remove two screws on each rotor.
Other than that, you will need two bolts to push the rotor off the hub.
Suggestions on which bolts to use can be found at this thread
