1 - 1 of 1 Posts
No So*p For Yo*!
for those who have ground controls and konis, what perch do you set it at? since the the gc are adj, do you put it in the lowest? highest? middle perch of the konis? any advice would be great. just wanted to know which is the "best" setting for the konis. i'm guessing it would lowest perch if i wanted it slammed, and highest, if not. which do i want to compress more? the spring or the strut? i can either put it on the highest perch and lower the spring, or i can put in on the lowest perch and not lower the spring as much... which is best? THANKS!!
JJ
1 - 1 of 1 Posts
