will a 95 motor go directly into a 91 car without modification? I was thinking there was really no reason it wouldn't, but I don't know everything, so please, anyone with an answer, a quick response would be great.
ntensehonda said:will a 95 motor go directly into a 91 car without modification?
Assuming you mean a '95 LS sedan, then yes it should be a direct replacement. If you're talking about a '95 coupe motor, then it would be a Type II and you would have to address a couple things.ntensehonda said:actually I was just wanting to know if a USDM LS motor would plug and play
Mostly Vacuum related.Kenso said:Assuming you mean a '95 LS sedan, then yes it should be a direct replacement. If you're talking about a '95 coupe motor, then it would be a Type II and you would have to address a couple things.
