Quick "?" on the tranny fluid change...
748 Views 3 Replies 2 Participants Last post by  mYbabYLeGend
Hey Guys,
Sorry for the dumb questions but I am trying to do the 3x tranny fluid change and I cannot figure out how to put the new fluid in the transmission. Is the Legend like other Hondas where the plug is somewhere higher on the transmission than the drain plug or is it somewhere else. Where is it easiest to access it from. I got the drain plug, I just need to find the other one. Thanks!
Hey
You just have to pour it in where the dipstick is, you need a funnel to do it. Good luck
-hass
Aaaahhhhh, that easy! Thanks mYbabYLeGend! Now I just hope I don't have as hard of a time removing the drain bolt as you did :) Thanks for the quick response!
:giggle: Good LUck make sure the car is raised properly,bc u have to use alot of pressure.
-hass
