1 - 12 of 12 Posts
This only happens once in a while but when I hit the gas, sometimes you can hear this light rattling noise comming from the front when accelerating. I also heard it on another legend. Everyone is saying it is nothing but bull! I'm noid . when i get noid i push pause on the deck till i get all the way home
I have the same problem, I forget what it was exactly, but was told by my acura dealer that something had corroded. Bottom line: It was gonna be $500 to fix that little rattle, so I'm putting it off.
Avarice said:
YOu say its in the front? Then i guess its not the heat shield then.
It sounds like it is in the front to me but people are saying it is the heat shield. I'm not sure, I heard fixing that isn't to hard what is the price range. (reasonable prices)
Discussion Starter · #8 ·
Acurate420 said:
5speed, i know what youre talking about mine had he same problem...mechanic told me to clean the fuel injectors, and put uprage from 89 to 93 on gas. after doing this problem went away.
All I put is 93 sometimes 94 but still i get the noise. It makes a beautiful car sound raggedy. How much they charging for getting the fuel injectors clean
Discussion Starter · #9 ·
$500 dollars:( bump that i'd rather get a 10 inch bazooka bass tube and let the bass drown the noise out:cool:
Blk/BlkGS6
naa listen,
i had the same problem, mine was rattling from the FRONT also.
my mechanic checked the cat and the heat shield was on it solid it was not loose. the heat shield over the exhaust manifold however was loose. this is up in the FRONT, under the engine.
my mechanic raised my car up on the lift, went under the engine and showed me the loose and rattling heat shield over the exhaust manifold. he then broke off the bottom portion of it, from under the car. he said you dont wanna take off the upper portion of this heat shield however, because it protects ur engine bay from possible fire. i told why dont u go ahead and take off the shield from the car also, he said i wudnt do it, unless it was necessary b/c ur cat gets glowing red-hot and if u ever get anything under ur car, plastic bag or nething like dat, it wud ignite. my problem was completely solved after this
hope it helps
Discussion Starter · #12 ·
LEgEnD4LiFe said:
naa listen,
hope it helps
Good lookin son
1 - 12 of 12 Posts
