I've searched and not found many good answers.
When you twist the rear pistons clockwise, about how far do you want to go?
Also, rear pads were down to nothing, but the pistons were out to compensate. So does that mean that it will slowly turn out so it's at the right distance from the rotor or something?
Because I just changed the rear pads and the E-Brake, which was tight even with the old pads, is looser now. Would this be because the piston needs to come out some?
Any help at all would be greatly appreciated.
Thank you.
Thank you.
