The 94 -97 Accord Clear Bumper Side Markers will fit, but as mentioned, are not similar in shape to the OEM. I found it best to remove the OEM marker bezel/surround (two phillips screws) then sand the lip of the aftermarket lens almost flush with the housing; both top/bottom as well as recontouring the LT and RT sides a bit. With trial fitting, the lens will fit snug. Then, as mentioned, a bit of clear silicone caulk to fill the LT and RT gaps between the aftermarket clear lens and the OEM bezel/surround. I also put a dab into the screw hole. From 3 ft away, it is hard to tell. The clear lens with a red bulb looks 200% better than the red OEM lens, esp on my silver cpe.
