Leon, I assume those are instructions for the coupe right?Leon Millette said:fyi...real quick
On the bottom of the seat...
You need to pull the two tabs on either side, while lifting up on the seat bottom. Once it has cleared these two tabs, pull up and out. You are trying to get the two tabs that mate up to the seat back out now. From there, there are 4 bolts that hold the seatback down. I think they are 10mm. Once these are done, push upwards and you will feel the seat coming out of the grooves
ooooooooh, sorry, yes this is the coupe...haven't toyed with my sedan's backseat yet...that is next timeWhiteLegend said:
Cuz there are 2 more 10mm bolts to remove, 1 behind the each rear head rests. You'll need to remove the head rest and there should be a split in the leather, and the bolt is right behind it.
