If you checked all the obvious things like making sure the master switch is ON, then try opening the rear door and look for the rubber groumet that carries the wire harness into the car on the C pillar. Pull it out, pull out the connector and wiggle the connector and see if the window starts movng. You could also clean that connectors pins, and a tip that one of the Acura Techs in the Legend Forums gave before was to slightly twist the pon conectors to make a tighter fit.
