I think it was around 6500 when it shifted. I'll try again to make sure.JackRabbit said:what do you mean by "just before redline" Are we talking a hundred RPM below redline? If so, isn't it possible the tach is simply lagging a little behind the true engine speed? If it is 1000 below, you might have an issue. My GS will hit redline in each gear, although I haven't seen it hit it in 4th.....yet.
Put in in 2nd gear and hold it to the floor. See where the RPM limiter kicks in. I should bounce up and down right at redline as the computer cuts the fuel.
I did that once, my 2nd gear actually went into RED ZONE haha 7k or so, so I shifted it to D3 manually haven't tried it againJackRabbit said:what do you mean by "just before redline" Are we talking a hundred RPM below redline? If so, isn't it possible the tach is simply lagging a little behind the true engine speed? If it is 1000 below, you might have an issue. My GS will hit redline in each gear, although I haven't seen it hit it in 4th.....yet.
what do you mean "right up to ther red line? does it actually shift on its own at some point at the red line, or you have to release your foot?JackRabbit said:Alik,
Hate to say it, but I just tested mine this morning. Right up to the redline in both 1st and 2nd while in D4.
Don't know what to tell you.
