Ok another alarm question...
I looked under my steering wheel the other day and realized that my car has a aftermarket alarm (Alpine SEC8048) installed but has no unlock remotes. Earlier to remedy this problem I had the hood latch wired so the system wouldn't arm.
Now I was wondering if I could completely remove the aftermarket alarm and see if it clears up some weirdness with my locks. Basically I was wondering if removing the alarm could cause any problems like ignition lock out or anything that would hurt the car.
Thanks,
-Ben
GS Hog
I don't know much about the alarms, but I'd venture to say that you should be fine if you disconnect the alarm brain. I did that to my previous Legend when the current owner was having trouble with it.
However, the wiredness that you mention is most likely caused your lock actuator rather than your alarm.
