1 - 6 of 6 Posts
Hi, I'm looking for instructions on how to remove the back seats from a 1990 LS sedan. (trying to repair part of the leather around the stitching) I did a search but it seems that the only instructions I could get were for the coupe from the honda UK page. Anybody got a link or a writeup? Thanks!
Should be the 2 center bolts that hold down the seat portion, then when you lift and remove this, you should see 2 more bolts holding down the back portion towards the outer edges. Once you take those 2 bolts off, you should be able to lift the back seat portion up and then pull forward. The only thing besides those 4 bolts are the four hooks on top in which you are lifting, then pulling forward
So I found two center bolts and two outer bolts and undid all 4. (I did notice that the seat bents used larger bolts and left those in) However, the bottom part of the seat still doesn't disconnect, and the back part of the seat comes up but is still connected up top. Any suggestions? Thanks!
hmmmmmmm.....once you remove all those bolts the only thing holding the seats in are hooks at the top of the seat back....and on the bottom.....hooks in the front. On the seat back you should be able to bang the bottom of the seats up and it should release the hooks up near the headrests. On the bottom......just pull forward...grabbing the back of the seat and pulling forward and up.
1 - 6 of 6 Posts
