I need to replace my antenna. I know how to R & R the antenna, but am having trouble getting to it. The car is a '91 sedan, and it seems that the CD changer needs to come out to get the trunk panel off to get to the antenna. Can somebody please clue me in on the procedure for uncovering the antenna before I break my CD changer?
Thanks in advance!
· I'van der Rohe
first you have to remobe the plastic cover from around the CD Changer. after that you go to the area hidden behind the tail lamp up in the cut pull the carpet fromt there and it should come relatively easily away from the fender. when this panel is removed you should see easy access to the Antennea mast. if you would like to remove the CD changer, for more working room, you should see 4 screws two on the side facing the spare tire and two facing the rear of the car take these screws out (philips head) and gingerly pull the CD Changer away until you see the connection (i.e plug) for the Changer( should be wraped in a funny type of foam like the inside of the new Jordan shoe case. unplug this and... BAAMMM ehen ehen(pimp laugh) your CD Changer is out.
hope this helps
one...
· Banned
hope this helps
one...
GOD HOW MORE EXCELLENT CAN THIS BE!! thank YOU i was Yanking on my CD changer and cursing LOL!
NOw i remove the carpet and remove the screws in it. Thank you
Thank YOu thank YOU!!! MWA!!!! :bowdown:
