How hard is it to remove the front driver and passenger windows glass of a sedan? If it's not hard, can someone post instructions? Thanks!
In order to perform this procedure, you really should have the applicable pages from the HELM. You will need the pages pertaining to the inner door panel removal as well as the regulator/glass itself. On the Cpe the inner moulding must also be removed. Any problem will not be in the removal, but in the reinstall adjustments. To list a detailed Step-by-Step would be much too time consuming for this method of info sharing and you will need the illustrations in order to make adjustments and remove clips w/o breaking them.
