There should be plugs under the seat make sure they are plugged up. After making sure they are all plugged up check the lights on the door memory button they will be lit up or blinking.
Well, i just plugged the seat up to the car for testing, hooked the front/back slide up to the tilt switch for testing, it worked, but it's sat so long the long spirals the gears slide on were corroded etc, so I took a wire brush to it and applied a bit of grease, they started working but were sticking in some spots so i was cleaning/moving them along to work out the kinks, and theyve stopped functioning all together. no more sound from the motor, when i manually turn the right one it feels tighter than it was, and the motor is HOT.There should be plugs under the seat make sure they are plugged up. After making sure they are all plugged up check the lights on the door memory button they will be lit up or blinking.
ya.If they are corroded bad you did clean off what you sanded b4 you moved it right?
It's def a ls it's poweredOP, what trim level Acura do you have: L,LS? '91 L passenger seat
adjusts mechanically. LS passenger seat is motorized. It is possible
to have an LS seat in an L model. That would require some work to
make it functioanal.
