Things Done Today:
Wheel Alignment
Tire Balance
Front Boots
Vehicle Speed Sensor
HondaATF
Power Steering Flush
Disc Machined (Leveled)
A/C Fixed (was just a small fuse)
My car feels so so much better now, solid all around. Shifting is much better with HondaATF, this is the 2nd time I use HondaATF (I did with my 1990 Legend too) the difference is AMAZING.. shifting is smooth now. Now I can tell what speed I'm really going again, braking is much better, no more shimmy, just plain solid!
Now that I have most things fixed, I can start picking out other things, example one:
-RPMs fluctuate slightly when traveling at lower speeds, I don't actually feel any difference in the car when it does, but still, I can see it fluctuate at lower RPMs a little.
-I know our cars aren't too great on fuel, but today I drove, 120miles I think, and my tank went from completely full, to a little above halfway, is this normal? I wasn't driving that aggresively etiher, D4 highway.
-Slight shake every once in the while when idling, as if the fuel isn't being supplied smoothly. It's only SLIGHTLY noticable.
Maybe I should try some BG44k for the fuel injectors? Haven't checked the Air Filter either...
-Weird metallic type of rattle or creek noise coming from underneath the car somewhere, sounds like something is loose, heatshield looked fine when I lifted the car the other day...not sure if that's it.
Wheel Alignment
Tire Balance
Front Boots
HondaATF
