So, I took out the lower panel (under the steering wheel) but I cannot seem to get the instrument panel out. Is there a picture that tells where the screws are, the only ones I see are on either side of the bezel but it seems that you would need some kind of 180 degree screw driver to get to the ones above the ignition switch (seems I would need to take off the ignition switch to get the them). Any help with this would be greatly appreciated, thanks in advance.
