1 - 20 of 26 Posts
Simple question...
How do I remove the rear speakers? Mine appear to have blown and I'd like to replace them. Also, what size are they? 6 inches? Doing some shopping on Ebay.
Thanks,
Chris
88' Legend L Sedan
Kenwood CD
The ones in my '90 I think are the same as the '88 and they are
6 1/2 " rounds at all corners...
Good luck...
88 Sedan rear speakers
I assumed they were 6 1/2.
Any idea how to get them out?
Chris
'88 L Sedan
Kenwood CD
Five- O
i have a 88 coupe and the rear speakers unscrew from the bottom- You have to go into your trunk. They should be 6 1/2 all around.
good luck
esti
'88 L Sedan Rear Speakers
I saw that they unscrew from the trunk. However, it appears that you can only remove them from the rear deck inside.
I've tried to pop the grills off, but with no luck. Don't want to pull too hard and break the damn things. Are the speakers actually attached to the grill?
Chris
'88 Legend L Sedan
first of all I believe the rear decks are 6 x 9 in the back and 6 1/2 in the doors and up front. The grill is not attached to the speaker it just has little plastic clips it should just pop off try using a screw driver. The speakers are attched from the top and bottom. You must unattach them from inside the trunk and then unscrew them from the inside of the car and they come out from the inside of the car. Make sure not to break off the connector clips for the gril because it will rattle like biatch if you do. If you are replacing the fronts good luck because you must take off the entire door panel to get to them the grill there now is fake it doesnt coem off!
Discussion Starter · #8 ·
Thats what I thought. I just have to put a little more elbow grease into popping off the grills. Just don't want to break them.
Thanks.
Yup... I just checked to make sure... The bolts go through the plastc grill ring, through the speaker housing and the nut is put on in the trunk !!
If you have the Bose stereo, I understand you have to replace with Bose speakers (assuming you still have the OEM Bose stereo). I have the base model so this was not an issue and I bought off the shelf speakers. Hopefully some others with the Bose can shed light on this.
Rick... It seems that there are people here that are having success with other types of speakers than just the Bose... There are threads in the Stereo part of the forum !!
I missread your post before and thought you had a bose... I agree that you should look at everything before you make a decision !! These forums are great for that !!
Five- O
you sedan guys have 6 x9 in the rear? Lucky bastards :D
Nope... I have 6 1/2" rounds in the back of my sedan!! Must be the Bose that have 6X9's....
I believe that the bose system are 6x9 in the back because my 88 coupe speakers in the front doesn't look like the back and when i measured the back to see what size it came out around 6.9 inches kind of look like a oval egg shape.
I have an 88 coupe Legend and I had no problem re-installing some Kenwood speakers, all you have to do is put some elbow grease into it man and pop the covers.... then unscrew them with a cross-head, thats all I had to do!
Discussion Starter · #20 ·
Actually, the rears are not 6x9's in mine. They are 6 1/2. Hope anyone else with an 88 L Sedan has the same. Just got my speakers purchased on Ebay today and will try to install this weekend.
1 - 20 of 26 Posts
