1 - 13 of 13 Posts
oMaiR
· aclegend
Discussion starter · #1 ·
Is there a DIY for replacing the axels?
can this be done without power tools?
and I chked the online manual, it says to drain the differential oil with a new one..is this necessary?
I got these things changed on the other one but im sure the mechanic didn't change the differential fluid..sud I get that done 2?
mine are getting pretty bad and the vibrations are getting worse..
thnks
PS this place is very helpful :)
Only need to drain the diff fluid if you are removing passenger side axle. Not too bad of a job, but you will need to separate the lower ball joint from knuckle without destroying the boot. (read: no pickle fork unless you are really careful/good/lucky). Impact really helps getting the hub nut off. Inner side pops out of diff with the help of a big screwdriver. Labor at a shop should not be too bad if you don't want to tackle it. Use NEW halfshafts, not remans. Napa sells for 100 a side.
You don't have to drain the differential to change either axle. They (ACURA) may reccomend it but it's not necessary.
I have changed approx 15 Legend axles over the last 4 years. The best advice I can give you is don't use remaufactured axles on the Legend. I learned this the hard way. This car is very sensitive to CV axles. The best deal I have found is NAPA "new" axle for $100
:werd:
~t.s.
Discussion starter · #6 ·
chked with Napa
allite I chked with napa and the guy is saying that the new ones I m referring to are made with remanufactured shafts but the other parts are new...are these the ones u guys recommend on this site?
just wanna comfirm,
thnks
From the NAPA web site
Constant Velocity (CV) Driveshaft - Left Front - New
Front Left Side Right Side
Item#: NMD946005
Price: $109.99
tax and shipping not included
Constant Velocity (CV) Driveshaft - Right Front - New
Item#: NMD946013
Price: $109.99
About how much is the labor to put axles on?
Discussion starter · #13 ·
sorry Jetdoc...nice info there man but Im in Canada and the guy here told me it totally different for Canada...but still I tell him the item #...lets see if he can get me the same thing here...
1 - 13 of 13 Posts
