1 - 14 of 14 Posts
I am just wondering if my RPM's are normal?
I timed my rpm's this morning - all rpms are while in Park & it was approximately 40 degrees outside
1700 rpm @ start up
1250 rpm @ 1 min 30 secs
1000 rpm @ 3 minutes
900 rpm @ 5 minutes
Eventually, the rpms settle down to 650-700.
Thanks.
Mine starts off at 2000 rpm and takes about a couple of minutes to settle down to under 1K. Usually it takes longer if its cold outside, sometimes as long as 5 minutes. I tried to adjust my IACV but couldnt get the cover off, thanks to my feeble arms.
1500 rpm @ start up
900 rpm @ 5 minutes
then after 10 minutes it usually idles at the 0-100 mark (really quite, sometimes i think the car is off) is that good for the car.Also one time it was idling at the 0-100 mark and shut off while at a stop light, is that a problem.
difficult to kill
1700 rpm @ start up
900 rpm @ 5 minutes
Thanks.
Your rmp is a little higher than mine @ start up:
1250 rmp @ start up
900 rmp @ 2 min
650 -700 rmp @ 4 min 20 secs and settles
I know this is summer time, but in winter time my rmp @ start up was almost the same as yours.
It's all normal.
1700 rpm @ start up
900 rpm @ 5 minutes
Thanks.
Wow... Mine is a little different...
1500 rpm @ start
1000 rpm @ 2 mins
400 - 500 rpm @ when its fully warmed up
1 - 14 of 14 Posts
