Hey guys,
So on my way home from work yesterday, I missed taking out a deer by about 3 inches at 60mph. Going down the freeway at about 80mp and three deer run out in front of me. In order to avoid hitting them I slammed on the brakes (ABS kicked in) and used the e-brake to slow down to 60 and 'drift' around the first deer and avoid slamming the second. It was more luck than skill that saved both my Legend and the deer. Then I noticed that my car was 'straining' to stay at cruising speed and pulling left. Brakes are seizing (but don't feel entirely frozen). I get home (DS rear wheel stinks like hot brakes) and go to a local parking lot to experiment. At low speed there is a rubbing sound from the wheel and a low squeal (similar to pads worn down sound. Applying the e-brake at low speed causes the rubbing sound to get louder. Here's my questions (after searching):
1. Does it sound like the entire LR brake setup is in trouble (caliper, e-brake shoes, possible warped rotor)?
2. Is it easy to distinguish whether it is the caliper v. the e-brake assembly that's sticking (looking for pointers on what to look for before I get under there later today)?
3. I'm going to try a quick fix of re-greasing slide bolts and fiddling with e-brake adjustment for now, but here's the real plan:
a. Rebuild them (paint too!) and get new(er) e-brake assemblies.
b. Rockauto appears to have some rebuild/repair kits, does anyone have a better suggestion for a parts source? acuraoemparts has something called a 'seal kit', is this the same thing?
c. If anyone has used these kits what components do they include? Are the available for the dual pistons up front too?
d. Should I reuse slide bolts or install new ones?
Rebuilding questions:
1. Best way to clean off surface rust from calipers?
2. Advisable to drain all brake fluid and rebuild current calipers, while leaving system empty of fluid OR buy used calipers rebuild and replace so as not to drain and leave system empty for a few days?
3. Stainless lines or keep OEM? I'm looking for a longevity and some performance (but not track levels).
