ok im planing on dropin my car like 1.5 now without a drop and my 17,s my car rubbed on the pass. side rear i had the fenders rolled n there fine now.... i went outside with the level before n check the tire it seams that the tire will rub when the fat part of the tire (where the tread stops n sidewall begins )will hit if my car gets that low over a pothole or sumtin.... ok if i drop it my top of the wheel will sit inn correct? but the question i was asking is that if anynoe has herd of or if it is even possible to get the offset of a rim shaved down to sit in the wheel well more cause i live my rims n dont wanna give em up....thank you ...jon
