how do i go about replacing the shiftgate bulb, the one that lights up the gears by the shifter. i removed that plastic around it but don't know where to go from there. also, what type of bulb does it use? thanks for some feedback.
EDM Honda Legend Coupe
Ok, I think, the Coupe and Sedan have the same procedure and location...
You must remove the whole dash board (wood cover). If you have an ATM (Automatic Transmission), you must (flat screw driver) pull out the small black cover, then remove the 2 screws (under the ash tray) and finally pull gently the whole wood panel. Be careful: ONLY PULL this panel ! This panel contains 6 clip holder (2x upper, 2x in the center and 2x lower). Then, you will see the small black bulb holder. Unscrew and remove it. Then you can see the small bulb (12V 1.2w = glas socket bulb).That´s all!
Mike / Cologne (Germany)
Re: Re: shiftgate bulb out
That´s it, what I mean... 12V 1.2W
I don´t know, which type of bulb you guys in USA have installed, but here in Germany, it´s 12 V 1.2W glas socket !!!
