1 - 20 of 25 Posts
So i test drove my car today for the first time (after the BHG job was finally done...i bought it with the BHG so i never drove it) and when I first shifted into drive, i felt a kick/jerk. Then, when i was driving, i felt it jerk again when it switched to second.
I used to have an old accord that did this too, and i was told it was normal. Is it fixable? I've heard that the problem is just motor mounts, but I want to be sure before I spend the money. could my tranny be going out? motor mounts? tranny mounts?
Also, my steering wheel is wayyy cocked to one side. When I'm driving straight, the steering wheel has to be almost like I'm making a left turn. It doesn't pull, and it drives straight, but theres a little bit of play in the steering wheel. Someone told me to get an alignment. Any ideas?
any help would be appreciated. My brother told me just to drive it, but since i got the car so cheap I'd like to fix it..i want it to be problem free.
The automatics seem to shift a little harsh. I used an automatic additive made by the same company that makes seafoam ( I can't think of the name) and my transmission seemed to shift a bit smoother.
Yes, get an alignment and they will center your steering for you.
anyone try the "BG SMOOTH SHIFT FORMULA"
i thought about it but its 40 bucks!
Its probably your rear transmission mount; its a common problem for Legends that comes with age or sometimes gets noticeable after an engine swap.
You'd have to replace the mount eventually. Sometimes a tranny service makes a slight difference in the shifting. Dont get suckered into tranny service at the dealer or a lube shop - they will kill your tranny with a power flush. All you have to do it to take it to your mechanic, put it on a lift, loosen the drain bolt, drain and refill with a bit more than 3 bottles of Genuine Honda ATF. My mechanic charges $10 for the labour and I am sure your mechanic won't charge much either. Don't bother with tranny additives. Honda transmissions are very finicky. The only thing I would try is Lubegard but the damn thing is harder to find than the holy grail. On a side note, a few of the obssessive compulsive members here (myself included) do a tranny drain and refill every other oil change. It may be excessive but for the cost involved, it is a cheap insurance to keep your transmission running strong for a long time.
Matthew is THE USER!
i had a little bit of jerkin .. but i mean.. you only feel it when ur giving it from 1st to 2nd.. if ur just cruising .. you feel nothing... ??:woot:
i felt a diff in shifting after i seafoamed my car too ..
I had the same "steering wheel not straight" issue when I bought my sedan and what had happened was, that when the previous owner had it towed
on a flatbed, the tow truck driver put the chain hook around the 'radius arm"
of the rear wheel and bent the hell out of it when he cranked down the tension. It is easy to see. Just look under the car from the back and look in back of the rear wheel. It is a curved flat-bar just perfect for a tow truck driver to put a hook on. Closely compare both sides and see if they match identically. I put a new one on and "Presto" , steering wheel level....
i just took a closer look at it and I think i might have the same problem as you.
I test drove it the other day, and i noticed that everytime i turned i would hear a tire screeching noise. I was in a shopping center today, and realized that i could hear the same noise everytime i went over a speed bump too!
I pulled over and took a look at the car from a distance and noticed that my REAR DRIVER'S SIDE wheel is sitting bent. its not noticeable unless you look at it, but the top part of the wheel is farther inside the wheel well than the bottom.
Does that sound like the same problem? this would be a good spot for a tow truck driver to put the hook on because the other side has the muffler in the way.
because i can.
I think you should at least take it in for an alignment...they will tell you there on the spot if its a simple alignment issue, or if parts must first be replaced...
Also, check out the 4x flush for the auto tranny in the DIY section....I hear it definitely helps!
^^ Sam O Nela has a good idea. That is actually how I found out that the
radius arm was bent. My tire shop says it happens all of the time. Always watch where the tow guy hooks up to your Legend. After they put a new one on, they did a four wheel alignment and no more steering issues.
my shifting (automatic) is pretty harsh too compared to the toyota camry that I drove previously. I mean, all the automatics that I have driven in the past have been really smooth. Couldn't even notice a shift. But on the Legend, you can feel it shift. I kind of like it actually. I think it's pretty normal for the Legends.
Hondas/acuras (at least from the '90's) always have a bit harsh or positive shift to them especially when pushed hard. It is normal and they are designed that way.
Discussion Starter · #12 ·
yeah, thats what i've seen among other hondas too.
i feel like mine is different though; i even get a kick when i first shift into drive. and then it only happens again when it shifts from 1st to second gear. after that, its pretty smooth.
on a lighter note, i was pretty amazed at the excelleration; it was SO much different from my old accord.
Discussion Starter · #13 ·
This is the part that looked bent to me. on the driver's side. its called the lower arm B in the pic:
any1 tried lucas transmission slip, i put half a bottle and it work for 1 or 2 days then acted up again. btw what will happen if i put to much tranny fluid will it do anything to my tranny b/c i put the half bottle of lucas tranny fluid without draining out any fluid, now its a tad bit over the full mark.
Toronto Legends
i tried the lucas transmission stuff, didnt feel any difference. still shifting hard between 1st and 2nd and slipping between 3rd and 4th. For some reason it doesnt slip if I switch gears from D3 to D4.....
Going to flush and fill tranny soon and see if that makes a difference
1 - 20 of 25 Posts
