No not yet, just trying to get ahead of the game.dHYUN said:did you get yours already?
Why might you need a lift?swift said:first off...i don't know how people did it without a lift. The only way i see is to get to angular ratchet wrenches....after taking console off.
It isn't to hard except for switching all the oem stuff over to the new one...I had a with that ball support spring thingee....lets just say u cant use my original anymore.
swift said:Give me a call whe you get in milwaukee. I know the perfect place to shift fastMy number 414.617.7280
Also i am headed up to campbellsport this friday....and we never ummmmm shifted fast. :2cool:
With everything sitting apart, I figure a piece of cake!Yeah...remove the snap ring and you are good to go...I did this job in my garage with my car on two jack stands....but that was on my G1 of course...
Any ideas on bushing sizes for the bottom where bolt goes???????????You can get to the bolt from inside the car, no need to get underneath it, it's just slightly more difficult. I didn't even use angular wrenches.
The only problem you may run into is the bottom of the shifter can rub up against the heat shield for the exhaust. I fixed this very easily by tapping it a tiny bit with a hammer. Apparantly the clearances are tight....
