1 - 6 of 6 Posts
I have a Champaign 1994 Acura Legend L and just recently purchased a set of side marker lights. I need to have them installed but have no idea where I should go to get them installed. It would also be helpful if I had an idea of how much it cost you guys to get them installed. I live in Chicago, Illinois. Can anyone help?
When my friend bought his, they installed them for him. The place u bought them from should b able to do the same, except if u bought them from the net. If that's the case, than i don't know where u have to go to. i have heard that they r easy to install, but I myself haven't done them.
Latin............................
I did buy them on the net...AutoDynamics. I am very hesitant to put holes in my car. What type of place did your friend buy the lights from (i.e repair shop, dealer, etc.)?
You need to have a body shop do the install. The problem will be priming/painting the hole and then using inner panel rust-proofing. Unless properly prepared and sealed, the edge of the hole will start to corrode.
1 - 6 of 6 Posts
