yeah, I thought I'd just let the shop tow it on monday to stay on the safe side
Since you did not listen to me before then listen to me now.LacyTheLegend said:I FINALLY picked up the Legend up today. The mechanic had put the head gasket on backwards. (spare me lee!) With the HG replacement the mechanic changed the spark plugs, but not spark plug wires, the car is still misfiring and the mechanic has told me to take the car to another shop that can 1. find out which cyclender is misfiring, 2. why my check engine light is still coming on. If these issues are related to the HG, the shop will pick up the bill. I am just thinking that since the cyclinder issue began after the spark plugs were replaced, that this problem is not a random. Also, it seems like the exhaust is expelling a little too much white smoke when I accelerate. There is just a little white smoke when the car is idling. How do I determine what is normal compared to what is too much?
You need to go to that shop and raise hell. File a complaint with the BBB if they are a member. Complain directly the owner of the shop, document everything youve been through. Take it back and show them that the problem is still not fixed after several thousand dollars and you want compensation AND your car fixed.LacyTheLegend said:IT OVERHEATED AGAIN!!!!!!!!!!!!!!!!!!!!!!
How should I ask for my money back??? I suppose all I can do is tell them how unsatisfactory their work has been, and even though they have taken a loss, SO HAVE I! Any other suggestions would be great! I'm dreading this!
