I have no idea how you do it or where the silicon goes. Can anyone describe the procedure? Thanks.
I hope he means detailing (i.e. CD2)infinite said:I am also curious as to the advantage of spraying the engine bay.
so wont the window be all greasy too then?legendarith said:I sprayed mine almost a year ago and my windows roll down nicely. You spray all the edges where the glass window touches. then move it up and down and keep spraying until you're happy with the results.![]()
dont spray the top part of the window the (horizontal part) the channels u will be spraying are inside the door positioned verticaly on both sides.ZiGGie said:
the problem with my window is that the horizontal part is what slowing down teh window. everytime the window goes down. teh two rubber part that I guess keep the water from going in n stuff.. it would be pulled downward. any idea what I should do with that?Roger said:
