ne1 know how to take out rear seats on our coupes?
yea i do. you lift up the right side. there should be one screw about where teh seat belts are. That should remove the bottom part. the top part just lifts upward. I removed mine about a month ago, so its still kinda fresh. if youhae anymore questions hit me up.
do whaa? i see a screw in each seatbelt thing. what do i do next? hold down the black buttons and lift up? what a/b the bottom part of the seats? thx. ESTI HELP!!!
ok just lookig at the bottom part of the seat. IF you are facing the back of the car. Lift up the left corner and you should feel some restistance. So now lift up where the left seat belts are and there will be a screw/bolt holding the seat to the car. Just one bolt. after you unbolt that, the bottom part should come off.
Here ya go...
This is from my 1987 Coupe Service Manual. It should be the same for your year as well. Just disassemble in the numbered order. Hope it helps. (I kept it full size for you to see better)
