1 - 2 of 2 Posts
MAN-WHORE
OK now I've heard that on most cars if you set your spark plugs to all be facing a certain positon when installed you can actually a get a little extra HP or better acceleration. For example if the open end of the plug is facing the intake of the gas/ or exhaust in certain vehicles it helps. Anybody experiment with this on or Legends? Im gonna change my plugs and want to know if anyone has found a sweet spot to have thier plugs facing by means of adding washers or anything? Every little bit counts is what I say!
I have to laugh a little because I posted my 2 cents long ago about this issue.
Now... when I had my R1, I did exactly that and obviously you can do this to your legend as well - however, although that MAYBE 1 pony you squeeze out will definitely NOT be the deciding factor should you run up against a like brethren.
Now... in it may calm things down a bit but... stamping the plug and ensuring its direction matches the intake port may just TRULY be the anally retentive dream.
KNLNGUS
1 - 2 of 2 Posts
