honda specifications requires less then 25,000ohm resistance so long as the wires are under 160 feet long each then it falls within specification.
Now heres the reason plug wires use resistance at all and bear with me, this gets strange.. its the the law! because your ignition system puts out alot of power, I believe somewhere in the neighborhood of 20-30,000 volts, and along with that power is alot of RF and electromagnetic interference. If you ran with zero Ohm plug wires then you would cause all kinds of problems to other electrical devices.. you ever notice how running a power line to a amp alongside speaker wires can cause sound distortion? same principle but on a much larger scale.. you would be setting off car alarms and all kinds of other things. back in the day the goverment feared cars could possibly launch underground nuclear missiles in silos just from driving near them.
With what your talking about I doubt your acura legend would be blamed for the start of world war 3 but you might have some problems with your stereo system and radio and possibly components of your ecu possibly causing you to lose power, maybe not enough for you to notice though
You can actually make your own plug wires by using wire that is less in ohms, which includes just about any wire that isnt a actual plug wire since they are one of the few wires with that kind of reistance. the difference between actual aftermark plug wires is that they use more insulation and silicone around their core to help cut back on RF and EM interferance.
hope this helped clear things up.
