I'm an inquisitive, innovative (not to mention frugal) kind of guy: has anyone on the forum tackled this job himself? $250 to $300 sounds awful close to set of summer tires ...if you know what I mean! Here's a note off another forum: "You have the classic problem of the Bose amplified speakers. The capacitors on the amp boards are failing/leaking and when this happens the amps may not work at all or sometimes the amps will make a squealing/popping noise in the speakers. If you use a magnifier and take a close up look at the capacitors on the amp boards, I'm sure you will see several of them leaking the electrolytic onto the circuit boards. It's a little time consuming, however with some patience you should be able to replace all the capacitors on all the boards to make the speakers work like new again. Or, you can always purchase four new amp boards at about $85-$90 apiece."
Doesn't sound like rocket science to me (although, I'm no rocket scientist!) So, if we can resolder main relays, rad fan control units, instrument cluster circuit boards, etc., how difficult can it be to replace a few components on a speaker amp board?
