BigDad,
Are your comments about lithium grease being ineffective based on fact, your experiences and is that just your opinion?
Interestingly, I had just returned from the parts store with some front brake rotors which I planned to install on my daughter's '89 Honda Accord when I read your comments. As a person who prefers to error on the side of caution, even though I have never had a problem with the lithium grease; I went back out to find some some brake caliper lubricant. I was not able to find the brand that you mentioned, but I did get some.
I noticed that the price is quite a bit more than the lithium grease. This is not a bad thing, if the extra cost is warranted. I happened to be in line with a mechanic who I spoke to about the use of lithium grease on the pins. He did not see it as a potential problem and suggested that it was possibaly just the opinion of an individual. I also noticed that the company, "CRC", that makes a number of brake maintanence products makes an aerosol can of white lithium grease. On the can it specifically states that it can be used on brake mechanisms and is effective in all temperatures.
Though I do a lot of work on cars, that is not my profession and I do not pretend to know it all. I am always open to learning better ways of doing what I do and, in this case, possiblely unlearning something that I am doing uncorrectly.
I did use the caliper lubricant on the pins of the brake calipers on my daughter's car and used the MolyKote M77 lubricant, that came with the OEM pads, on the shims. However, before I make the permanent change to caliper lubricant instead of lithium grease , I intend to do some additional research. So, if you know of a source where I can find additional infromation, I would appreciate hearing about it.
Thank You & Take Care, WHM
