502MotorSports.com
not worth it at all...
the stage II chip is wht you need if looking for performance ----
7-8hp/10lb tq AT the wheels across the ENTIRE powerband, not a peak RPM
the stage I chip may anger you due to loss of power:eek:
Stage II chip is for if you plan on or have mods (intake, exhaust, etc)
Question...
Could a person buy the stage II now, install it on a stock legend, and drive it around without the intake and exhaust mods?
Then once that person gets around to it, put on the intake and exhaust on and the car is good to go....
Would the car run really crappy?
502MotorSports.com
Mckenzie91 said:
Question...
actually, you'd be fine either way. All you would need to do is pull your ECU fuse for about 30 seconds or disconnect the (-) cable from your battery and poof, you will be good to go (once you've added your mods)
