dudes, i will buy anyone a pack of beer if they figure this out (if you're in MN), even if its a stupid reason for it doesnt start. when you put the car to the start position (where all the lights turn on, blah blah, etc). when you try to start it, it doesn't even crank period. what the person before did was use a ground wire, touch it from the positive battery terminal into this wire that goes into a plug, which is between the fuse box and the battery on the driver side. its a gray plug which has 2 wires going into it. once they made that connection, the car would start. any ideas? its a on a 93 legend GS. PLEASE HELP ME
