1 - 20 of 21 Posts
My legend has started to have a static sound come over the speakers. It stays there whenever the stereo is on, however it remains at a constant volume, even if I turn up or down the volume. Any ideas where this sound could be coming from? I had the amp replaced by acura under the recall less than a year ago. I thought it could be coming in from my subs, but I removed the power to them and the static remained. Ideas??
It could be alternator whine, not grounded right, etc... Do you have aftermarket head unit? You said the amp was replaced under a recall, maybe the problem still exists?!
· Blk/BlkGS6
i have the same prob...............wen my system is on, even if the volume is turned all the way down, i can hear this hissing noise.....................when i turn off the system it goes away....................yeah i have an aftermarket deck and changer.................but no subs or amp or anything.
any help???
same thing happened to me a while back. heres how you fix it (bear with me here cause it seems silly). if it is the stock bose headunit, pop out your bass knob and give the end a good flick with your finger. i dont know why this works but it does....i would still like to know the cause of the static as well....because it comes back from time to time when it is cold out. hope that helps.
91coupe LS
The two that I have seen...1st one, just simply connects between you RCA's. The other is more complicated and incorporates the power and ground wiring. The 1st one is definately the easiest for those that are running external amplifiers!
· Toronto Legends
i have the same problem...happened 1 hour before my birthday....this is killing me.....the legends not the same with the bose stereo....i need my music people.....please help!!!!!!!!!!!!!!!!
· Stop eyeballin' me, dawg!
Couple of potential free solutions.
#1) (I think this was Qboro's solution) pop the bass and treble knobs out and lift up on them with your finger tips. not to the point of bending them, but crank on them till your finger tips hurt. Sometimes it makes it go away.
#2) (my solution, 100% success rate in my car) with the treble knob pushed into the "in" position, push it in with the edge of your finger, and roll your finger out of the way so that the knob goes from extreme "in" to full "out" with a snap ( be prepared to catch the plastic part of the knob, mine has shot off into the back seat a couple times). For whatever reason, it makes the static stop :headscrat
If it doesn't work, hey, it didn't cost anything to try it.
· SGM / Type F
6 year bump!!! Woot!! Try fiddling with your bass/treble knobs as 4dr said and see if this affects the noise. Eventually the static will return and replacing hte stereo is the only permanent fix, unless you have experience with soldering on PCB's/diodes etc....
HAAAAAAAAAAAAAAAAAAAAAAAA...OMFGGGGGGGGGGGGGGG........my radio 1st went staticky about 2 yrs ago...only for a week though then it was back to normal...ok no big deal....about 4 months ago it happened again...on n off for about a week then it just went crazy the only way i could listen to my radio without hearing the statik was 2 play it almost at full volume... i love music but honestly it was 2 fuckin annoying...i had to just stop listening to my radio unless i was twisted...then i could put up with it just to hear beats...lol...i just went downstairs.." spun " my treble button haf way around with my finger...thru the radio on...& BANGGGGGGGGGGGGGGGGGGGGGG....no more statik...off the hook...good fuckin lookinnnnnnnnnnn...fabulous!!!!!!!!!
When that happens to me, I change my old Spark plugs and that fixes the problem for me.
If you have old spark plugs or cheap spark plugs, give it a try.
· Toronto Legends
the flicking worked for me!!!!!!!!!!!!!! lil jon says "yeah"
stupid fucken shit but im happy now
btw...i did change my battery just a few days before that...may be that was it
1 - 20 of 21 Posts
